natur
продается пульт JB-LIGHTING LICON 1X
natur    0
JB-Lighting Licon 1X - 1024 DMX channels for use with scanners and PAR lights. thomann 32x scanners with a maximum of 25x channels (each), large graphical touch-screen LCD display (120 x 90mm) with softkeys and encoder, encoder controlled pan/tilt, PC trackball or mouse. 8bit or 16bit pan/tilt channels, scene memory, 32 of the 96 chasers work simultaneously. Sequence thomann controller with go button, sound, time crossfader. External control available via MIDI, SMPTE or sound. Chaser generator. CD-ROM for sound programming. Backup on floppy disc. DMX In port for extending with other DMX desks, USB slot for easy backup. Dimensions: 660 x 520 thomann x 170mm (approx).
Из за ненадобности продается пульт, состояние на 4, стоял в ночном клубе, цена за сей товар 65 тысяч российских рублей. Пульт находиться в г.Омск
