Lite-Puter Dx-1220Manual (Eng)
Admin    0
index.php?app=downloads&module=display&section=screenshot&id=98
Добавил: Батурин Алексей
Добавлен: 17 дек. 2012
Категория: Мануалы/Manuals(Eng)
Chapter 1. Introduction
1-1 Features of DX-1220
1-2 Structure
1-3 Specification
Chapter 2. Installation and function introduction
2-1 Installation
2-2 The main function of P-27
2-3 Introduction of DP-5
2-4 Connection of DMX & ANALOG
2-5 Real panel
Chapter 3. MODE
3-1 DMX mode
3-2 ANALOG mode
3-3 OFF mode
3-4 How to set the start address of channels
3-5 How to connect with over 2 sets of DX-1220
Chapter 4. FUN (FUNCTION)
4-1 Display dimming level of each channel
4-2 Dimming level testing for each channel or all channel
4-3 Fade in and Fade out automatically testing for each channel or all channels
4-4 Display the Voltage
4-5 Display internal temperature.
Chapter 5. SET
5-1 Set dimmer-warm up 0% --- 6%
5-2 Set dimming or switch for each channel or all channels
5-3 6 memory scenes --- be use for architectural lighting with CP-2A
5-4 Set fader time
5-5 The corresponding list of setting fader time
5-6 Set "square" or " 3 linear" dimming curve
5-7 Maximum wattage limit setting
Chapter 6. Specification of plug & wiring diagram
Нажмите здесь, чтобы скачать файл
